Does Wyze Lock work on double doors?
If it’s a deadbolt and it lines up correctly I wouldn’t see why not.
@kinwong44 Welcome to the community!
Are you able to upload a picture of your current deadbolt? If you have a standard deadbolt on your door it should work.
@kinwong44 Thank you for uploading the pic. I would say your deadbolt will work with the Wyze Lock without any issues. Take a look at this simple installation guide in the support article below. This will give you a good head start on installation.
