Wyze Lock Bolt needs to color one side of the latch knob to see if locked
Unfortunately the light near my door is quite dim, so I cannot see if the door is locked or not by looking. I do have the auto-lock on so it should ALWAYS be locked. But I’d prefer a visual option to notice, without starting an app, or turning a light on. I actually added some tape to one side, so I can tell if the tape is pointing up/down or left/right. I feel this shouldn’t be difficult to do, and it doesn’t even need to be an arrow, or something that would require you caring about how it is installed. Since it all the same color, it is just more difficult to tell at a glance if it is locked.
Thanks.
