Wyze Lock Bolt installation in metal door?
I bought the Lock Bolt and went to install it, and found the deadbolt latch has a faceplate installed that does not appear to be removable. Which is a problem for me since I have a metal door that I cannot chisel a mortise into. For this reason, many lock companies (Schlage, Kwikset, etc) allow you to remove the faceplate for “drive in” installation.
Example from Schlage product:
Wyze’s AI assistant claims this is possible, but it sure doesn’t seem like it’s meant to be removed. And I’m worried it’s going to break my deadbolt. Has anyone tried this?
