Wyze lock bolt doesn’t have keypad settings option
I’m trying to add codes for my lock bolt and it says to go to settings then keypad settings…, but that’s not an option. Any advice?
Welcome @phillyfan9
To add additional Access Codes, you need to go to the Access Settings Option. Then you can add users and codes
Thank you! The app instructions should be updated, this is what it says there
Those are the instructions are for the Lock and not the Lock-Bolt. :slight_smile:
It can be a bit confusing though.
