Wyze light strip or strip pro
Hi, does light strip and light strip pro detect motion?? Does it have an in built motion detection sensors??
Thanks and Regards
Thanks for your response. Nothing much …since I stay in a condo …it would been great if I can get motion sensor based strips on both ends (going up and going down).
Any suggestions???
That’s a great idea. However I have Google assistant and not Alexa. So I will figure out the rules for it. But instead of setting rules I am more inclined towards having it work via a motion sensor. I don’t want to purchase additional motion sensor compatible with the strip… additional equipment additional issues. If all comes in one, that’s always helpful. But thanks for all the assistance. I really appreciate it.
Thanks and regards
