Ok, I kinda get it!
But various speed tests point to my ISP. My ph is 22.0 MPS.
Not Blaming Wyse products at all!
I had this same set-up since June no problems.
They all worked just fine til 2 wks ago.
I conducted a Laptop speed test (direct connect) and verified my not so normal 0.8 Mps download speeds.
I’ve Never had more than 1.1 Mps from a sorry national provider (8 yrs).
I contacted my Modem / router provider last wk and as you pointed out. These device don’t take up bandwidth or create congestion.
So, he instructed me to shorten the DHCP lease times.
Which I did from 12 down to 4hrs.
I will also try changing the Bandwidth Pipeline from 20 MHz to 40 Mhz (lower)
So, I am trying to obtain a temporary fix. Until I go 4G hotspot Unlimited. Rather than bother with provider throttling and or 1970 internal phone lines n wiring.
I replaced the ph companies junk modem / Router (Bitsurfer?). With one that ran just fine til now.
Hate to buy more stuff that will need to be replaced, for 4G or 5G hotspots n alike.
Thanks for the reply!
I will look into the subnet configuration mention in the other post too!
Wyse was never the problem as I intended to state, from the very beginning.
But, this is a busy n has been a very busy year ( caring for an aging Vet.) My Dad,
He’s 97 with dementia and I am trying to get his finances straightened out. As he battles us to remain relevant. While letting things financial go to waste!
So, any n all help is always appreciated! Thx!
