Wyze Home Security Starter Kit Subscription Question
Hi guys,
Is it possible to use the security system without the subscription? I’m only planning to use it for notifications. Not even sure if that’s possible without the subscription.
Thanks guys!
Yes.
The v2 sensors and hub work just like the V1 sensors, if you have them. You can use them to turn on plugs, bulbs, cameras and the like as well as send notifications without the HMS subscription. Theoretically, Wyze is planning to sell the hub and sensors standalone at some point in the future.
If you mean will it work as a security system without the subscription, the answer is no.
