Hello-
I just got my Wyze Home Monitoring Kit. Because of the way the molding around the door from my mudroom to the garage I cannot use the contact sensor sent with the kit. I had installed from my prior monitoring company (frontpoint) a contact sensor that is inserted into a holes drilled in the door and the door jam, which worked great. Does anyone know if there is a way to connect these sensors to the Wyze system?
Thanks,
Eric
