Wyze Floodlight Pro & Window Cam Firmware Beta Test 6/29/2026
Wyze Floodlight Pro Beta:
Version: 2.2.1.1343
What’s New:
  • Faster live view with more stable streaming.
  • Improved microSD card experience.
Wyze Window Cam Beta:
Version: 1.3.0.52
What’s new:
  • Fixed a bug that could cause SD card recognization failure
  • Added MicroSD card using guidance
  • Added MicroSD card Insert/Remove Notification
Note:
  • Insertion/Removal Notification will only be available with App 3.16 and above.
Can someone please help me with my issue?
I went to do the firmware update on the update page and it says no devices on my account. But I have about 100 devices. Does anyone know how to fix this. Any help would be greatly appreciated.
TIA
Can you do the following to see if the flood light Pro has been selected to receive Beta Updates?
  • Start the App
  • Go to Account
  • Scroll to the bottom and select About
  • Tap on Beta Program
Then go through the list of device types and make sure there is a green Check to the right of it.
I personally do a Unselect All, located at the top right, then do the Select All (Unselect will change to Select) to make sure all devices have been selected. If you want to select certain devices then simply check the square to select it.
Then click the save button and it should back you out. to the about page.
After you do this, you will need to wait for a period of time to make sure the servers are updated with the beta requests and you should see it.
If no devices are showing in the list at all (I imagine you’re looking in the app at  Account ➜ Firmware Update), then I wonder if there’s a profile error that could be resolved by clearing your caches. That’s probably the first thing I’d try.
This is how I tend to clear my Wyze app caches on Android (click/tap to expand):
  1. Clear the in-app cache: From the Wyze app’s home screen, navigate to  Account ➜ App Settings ➜ Cache File Size ➜ Clear.
  2. Swipe the Wyze app out of the running Android apps.
  3. Long-press on the Wyze app’s launcher icon (on the phone’s home screen or wherever you tap to initially open the app) and then tap  App info in the pop-up menu.
  4. Tap Force stop on the App info screen (may need to tap OK to confirm) and then tap Storage & cache.
  5. Tap  Clear cache on the Storage screen.
  6. Back up one screen (back to App info) and then tap  Open to re-launch the Wyze app.
Note: I don’t know what the options would be for modifying these steps on iOS since I don’t use that platform. If using iOS/iPadOS, you should be able to clear the in-app cache with Step 1, and that may help.
Sometimes I stop at just clearing the in-app cache, and often that’s sufficient, but occasionally I’ll clear the OS-level app cache, too.
Thanks I just did it all and I guess I’ll wait until tomorrow to see if the page repopulates correctly.
My monitor page also is saying something is wrong and not working…
I would also follow the steps that @Crease provided. Clearing the cache from within the app and then from the App Info location, for Android, normally clears the anomalies up.
Sometimes the Cache gets corrupt and requires this on occasion.
Curious, what App version are you using?
I am on App Version: 3.16.0.890 which is the Android Wyze App.
I’m on the same version as you on my android phone.
Thanks - that helps.
I see my beta Updates and did install the Floodlight Pro, so I am sure it is something simple
I just used my older tablet and the list shows up.
I’m guessing it’s either my pixel 10xl being on a beta or the app isn’t playing nice with it. At least I can update. I’ll see what the next app update does. Thanks
Anyone test this on a iPhone cause I had to have roll back the las time for the floodlight pro not working on Cellular. Thanks appreciate any advice
Thanks, this seems to clear up the issue with cellular live viewing on the floodlight pro
Anyone seeing this new issue on this new version …1343
Once micro SD is full, camera stop working. Recording will not rollover. Can not access live view. No cloud events stored. No motion detection. Basically, everything is paused.
A Restart is required and appears to get things going again. Note that I have Continuous recordings enabled.
This is pretty serious particularly since the camera stops working and there’s no indication what the issue is.
I’m making the assumption that some bug crept in whereby the FW unable to rollover once SD card full.
Why do I make this assumption? Just read the release notes SD card improvements” and you can pretty much bet “improvements” usually mean something else got overlooked.
