So I purchased and installed 2 Floodlight cam pros 15 months ago. Both of them are now unable to load live stream from the Wyze website, my phone (android) and my wife’s phone (android). They’re both on 2.2.1.1135 firmware and they both have a good signal strength (2.4 Ghz) Wi-Fi. They both started having this issue at the exact same time. Has anyone experienced this? Any known issues? Any fixes in progress? There are at least 2 newer firmware versions available for the cameras but they’re both reporting up to date. I’ve turned the breaker off for 10 mins and done a factory reset but, the issue still persists.
If anyone else is having this issue I found the solution. The fix is to cancel your wyze subscription, remove all the wyze cameras and replace them with eufy products. Eufy works a lot better, no subscription fees, and its all local.
