Common, where is your adventurous spirit young man?
I was adventurous today, I updated the V4 Firmware.
Does that mean I can go ahead and update mine? Just like you I only have one v4 and no spares to [mess] around
Mine is still working
That is re affirming, I’m doing it as we speak.
please tell tomorrow if it still works and then next week, perhaps I will feel lucky to press upgrade button
It works with no issues at all.
There is an issue with v4 on iPad in landscape mode. Not sure if it is firmware or beta app. When smart focus is selected and you select single camera view in landscape, the view is zoomed in and you can’t zoom out unless you turn smart focus off. It acts the same from both beta 3.0.0 (9) and previous early release of the app.
This is the view with smart focus OFF
This is the view with smart focus ON
Submitted log number 1478821
Just did a quick check under Android 14 using production app 2.50.7.487 and definitely don’t see that issue.
Yeah the crickets have been really noisy the last few days. I told my Lizard Army to round them all up for lunch.
Everything is fine on the iPhone, it’s just the iPad in landscape mode
Just checked Android tablets and can’t reproduce. Perhaps the issue is unique to iPadOS? Hopefully, someone @ Wyze will check your log 1478821 out.
Are there any plans on fixing the issues with Video Clips not playing on iOS 18 Beta?
Other than erasing and resetting my iPhone, is there anyway that WYZE can send a patch update to get those Videos playing again?
I don’t think WYZE would help out Apple, especially with a Beta operating system.
I doubt Apple would even listen to Wyze, especially with a Beta operating system.
That’s a cool looking fancy Feline
Every in the surrounding area knows about the water supply thanks to that big mouth MFP who camped out here for numerous hours last night.
Well, yeah, he found a limited magical resource that refreshes itself. He’s protecting it and sharing it with his kind for a fee. This is how Ca(t)italism is designed.
