I am having some issues with my Wyze Duo Doorbell. Any help to fix the issue is appreciated.
- It fails to speak out motion warning when anyone is near to the doorbell.
- Unable to get sound from Microphone
- Quick responses not working.
My doorbell is wired and everything else works fine. I tested the above feature when I received my doorbell and they were working randomly.
Welcome @Richie_Cooper
Curious if you have setup Detection Zones?
If so, can you disable and try again to see if it get corrected? Would like to know if this is related to another reported issue.
BTW: I am not a Wyze Employee, but help out when I can.
I need to check the mic on the doorbell. Haven’t done that yet.
Yes. I am using detection zones. I’ll try to disable it and see if that works.
Please let me know and I will add it to my report
system
Closed
