Installed the wired Wyze doorbell v2 but it’s detection is acting super buggy:
- The camera is detecting people passing by on the street, but when someone walks up to my door and presses the bell - it does not detect. This is horrible and makes the product useless.
- Apparently there is no notification for actually ringing the doorbell. I also checked the settings and there is no setting for ‘notify when pressed doorbell’. I have a doorbell pro and it has the option. It should be tablestakes to notify on doorbell press.
- Detection Zones don’t work at all. Nothing in the zone which was designated as detection area is being triggered.
Are you on the most up-to-date firmware? If yes, there’s a known issue with notifications that they’ve been “working on” since April.
I just bought this yesterday and updated the firmware the first thing. So yes?
Ok, yeah, so your options are either:
Wait for the fixed firmware and deal with no notifications until then (and Wyze hasn’t given an ETA on the fixed firmware)
Exchange the doorbell > force quit the app when it tries to force you to update it during initial setup > turn off auto-update (Wyze V2 Doorbell not longer recording events or sending notifications - #24 by Salor)
Personally I went with option #2. Not an ideal situation overall.
Same here. I noticed one day it was offline for 8 hrs or so then back on and i havent had any notifications at all for days. Cant they just fall back to the last firmware till its fixed. This will be the time someone steals a package with a camera that cant record
I have the same problem. I get detection of trees blowing, but it doesn’t pickup the Amazon guy delivering a package. Absolutely useless.
