I did not find a Doorbell v2 in the Tinycam pro app. Did anyone get this to work?
Thanks Jay
Yes, just go to Manage cameras, select the plus sign then add IP camera, For the Camera model, just leave it on Wyze Cam:
Enter your user name and password and in the camera UID, choose the VDBv2. When you try to stream it, it may ask for your 2FA code the first time if you have that set up.
But it definitely works. I use it.
there is no sound on bcp
Thank you worked perfect. One thing I noticed is it sounds like audio is slow like it was dragging.
