Wyze Door bell constant noise
Finished installing my new WYZE doorbell tonight, and man, I turn on the speaker and there is a constant low grinding, chattering sound that just does not stop. This thing is as noisy as heck. and LOUD. What is the problem. I wanted to just record the video and sound I was hearing, but apparently I can only record events after motion is detected., but even in these videos the noise is there in the background and apparent. What is it?!
Join us over here where we are lamenting on this very issue…
Just installed mine today and was just about to post this same issue. It’s loud and annoying, glad I’m not the only one. It already had a firmware update which I did so I’m on 4.25.0.222. Looks like this might be a hardware issue that needs to be addressed. The sound to listen to someone at the door is pretty much unusable.
I am facing the same issue. Anyway to fix this issue or should we return or doorbells back to Wyze?
I also have such problem, the voice received from the mic is too noisy, unable to hear.
any updates on this? mine is noisy as well.
Old doorbell is terrible. Pro Doorbell fixes this. Much better overall.
