Wyze cordless vacuum lost green piece that goes around filter
Wyze does not make a replacement piece. Does anyone have suggestions or found a replacement for the green piece that twists around filter?
If the vacuum truly lost the part on its own, it should be easy to trace where your vacuum has been. Does it go outside? :thinking: Or go under a couch?
This is for the handheld vacuum. I think I lost it while dumping out canister over trash can so it is long gone.
Wow, I’ve never had that part untwist and fall into the trash. The bin gasket yes, but not that part. Wyze really should sell replacement parts.
Did you ever find an option? My kids threw mine away as well
