Wyze bible color looks beautiful. The problem I have with it is that you can not program it to come on with a specific color. If I want it to come on at 11pm in Congo Blue I should be able to. Not just warm or cool white.
this is something that was brought up in testing A LOT! and rightfully so.
this option is currently in #beta and working great so far with the rules I have set. so it’s just a matter of time before it hits the production app ![]()
Edit: so thanks to another awesome maven I believe I confused what’s in Beta with the new rule engine that is being rolled out. so the option/ ability might be available only to those currently with the new rule engine ( which makes more sense) but either way it should be out hopefully in the next few weeks.
Yeah I would have thought that this was the whole point of a color bulb. One needs to be able to have it turn on to a specific color at a certain time of day for instance or to be able to set its colors within schedules and within integrations for instance with google.
And while I am on it, integration with Samsung Smartthings would be nice.
I found a work around that has been working for a couple weeks for my situation. I set the bulb to the color I want then leave the switch on. Then set a schedule to turn the bulb OFF instead of ON. Comes back on blue every time. Hope that helps.
No, that does not help. Need to be able to set the Color of the Bulb in a rule of automation. I have no idea why this was not thought of when the Color bulb was added to the Wyze System.
