Hello friends,
We are conducting a very short survey about cloud storage retention duration and would love to get your feedback.
Hello friends,
I have rarely needed events farther back than 14 days, and on cameras I DO want them to go farther back, I just get a large SD card (256GB, 512GB, etc), and if I need it to go back even more than 1-2 months, I will either switch it to record events only (instead of continuous recording) or I will have it save recordings (sometimes even lower resolution to conserver space) to my NAS which can save events going back years if I want.
But generally, 14 days is more than enough and I wouldn’t want to pay more for larger cloud storage.
Having said that, IF this was offered at nearly the same price, I would find it beneificial in the following use case: If I had Cam Unlimited Pro with AI search capabilities where I could tell the AI what I am searching for in an event, and have it scan back to events even farther to see if it can find what I was looking for. For example, maybe I notice something go missing in my house. I tell the AI search to look for the latest event that it can identify that object in so I can try to locate it or see who was holding it, or whatever. In some cases I may not know WHEN the object went missing or when I last saw it, so if the AI had access to more events going back a month or more, that would make it more useful for situations like that. That is the main benefit that I, personally, would appreciate having longer cloud event storage for.
I also rarely view Cloud Event videos that are 14 days old. Back in 2022 when I bought my Cam v3 cameras i bought 32GB high endurance cards for each v3.
In 2022, 32GB cards were:
I have some larger capacity SD cards on my shelf, but i have not had a 32GB card die yet in over 4 years. Because of my situation, i have gotten in the habit of saving Cloud or SD card videos within 3.5 days.
you copied my answer didnt you ![]()
almost excatly the same!
I never go back 14 days and answered as such.
But, considering what Micro SD cards cost these days, I might reconsider.![]()
