Wyze Car image flipped
The Wyze cam V2 I used to update to the Wyze Car firmware was previously used upside down, and I had the image flipped in the app. It appears that it kept that setting when updating the firmware and I don’t see any way in the Wyze Car app that will allow me to flip the image.
Did I just brick this camera?
Thanks for the help!
You need to flash back to a normal V2 firmware, then reset the 180-degree setting using the normal production app (not the Beta app).
So when you first load the Car app, you will see a ‘person’ menu in the upper-left corner. Press that, and then “Switch Cam Mode”. Then select “Use Camera Mode”. When it says “Success”, go to the production Wyze app and change the 180-degree setting.
Then go back to the Car app and update the firmware back again by going to the person menu on the first page of the car app and selecting Switch Cam Mode > Use Car Mode.
Then you will have car control back, right-side up. :slight_smile:
That did it! Thanks so much for the help
No problem. Thanks for the follow-up! :slightly_smiling_face:
