Can’t get WYZE cam V2 to recognize my sd cards.
I have 2 different SD cards both formatted on PC with FAT32
Both class 10 rated cards
LEXAR SD card capacity 29.8
Sandisk SD card capacity 29.7
I put card in WYZE cam
Power up the WYZE cam
WYZE cam will not recognize either card.
Camera is set to ON
Power up the camera before you put the card in , that is the way I have always done it and never a problem.
I never turn them off to put in or take out the cards
I powered up the camera before I put the card in also NO LUCK.
I reset the cam and started from scratch NO LUCK.
I deleted the app turned off my phone then reinstalled the app NO LUCK.
I went into my phone and gave permission to everything on the WYZE app NO LUCK.
My sd cards worked fine when I first put them in both cameras. Now 3 days later ‘no sd card found’ about 1/2 the time. I don’t do anything and then try again later and it works fine.
