My understanding is that there is a Beta firmware in testing that addresses a few things ( July Beta was released), one being network performance fixes/optimizations.
Not sure when it is expected to be released,
once beta testing is completed.
I had tried dropping the frame rate to 360p instead of HD or 2.5k and it made no difference, still happens.
My firmware was updated to .13 from .10. I am using the TestFlight beta, and RTSPS is still an option in the app, but it’s not giving me a good URL link, and I’ve tried it in way more than one program.
I went through the screens to setup… I don’t have RTSP to test it but I was given a link that says:
rtsps://192.168.95.65:322:stream0
My guess is that link is not directly translatable into the particular RTSP 3rd party platform you are using. You may need to modify the link to make it more agreeable to whatever you are trying to use it on.
It connects, then immediately disconnects. To get it to reconnect, I have to go to Edit Network Settings again and hit OK; it reconnects, then disconnects again!
I have five Wyze Cameras v4’s and ever since Beta Firmware 4.52.17.10 there has been issues with connectivity on the web portal while watching live view, it continues with 4.52.17.13.
The cameras would randomly lose connectivity in the web portal live view and try to reconnect and sometimes they do while other times they do not. I have sent the log pertaining to issues on the web portal after it can’t reconnect. This happens randomly with all five of the v4 cameras on the web portal.
i would like to report an issue with the rtsp implementation in the wyze v4, firmware version 4.52.17.13
i have the camera connected to frigate NVR over rtsps.
about 1-2 times per day, frigate will lose connection to the camera for about 15-45 seconds. this does not happen on any other rtsp cameras connected to the NVR. during this time that frigate loses connection to the camera, it is still accessible via the wyze app. and records to sd card just fine with no break in the recording.
i am using a stock config in frigate with the stream***
“rtsps://user:pass@192.168.0.50:322/stream0/”***
if anyone from the team or anyone else has any ideas on what the cause could be, please advise.
