I tried both ways, even did the sd card firmware, still can not connect. I am about ready to give up on this one, and get a new cam, thinking about unstalling app and re installing it, to see if that helps.
What version did you flash back to?
4.36.9139 is the version the link took me to. Edit to correct the version numbers
Try clearing the App Cache before uninstalling the App.
Tried that, still can not connect
Going back to any 4.36.9.xxx version from 4.36.10.xxxx requires a full factory reset on the cam again after downgrade.
Tried it, after 1 and half hours, it is flashing red, still can not connect. Tried everything suggested so far, with no luck. Im starting to get fed up with it
now, I cleared the cache in the app, the app does not show anything, un installed app, installed again, still nothing in the app, just a blank screen. not sure what to do now, I can’t use the cam or the app
I had the same problem. I ended up installing the regular wyze app(not beta) on a spare phone. Did the manual flash/reset. Deleted the cam and reinstalled it. Now working with the older firmware. My cam doesn’t like the new beta version.
I dont have a spare phone. Its odd the app is messed up to. Guess ill give it a try
Just for info, i have a samsung s20 ultr, running android v13
I have a Pixel 4a using the beta app, so I used my spare phone,LG G6 and loaded the regular wyze app (used my other email for the Google play store), so I could get the non beta app. Logged in with my wyze account and did everything from previous post. Afterwards everything looks good, both app versions.
left the Bata, running the public version, still will not connect, even reset the camera, not sure if not having a password on my wifi or not (which it did work without having a wifi password before the update), or if the 2 step verification has anything to do with it or not, just can not get it to work. this is frustrating. even trying everything in the Wyze Cam v3 Troubleshooting, with no luck. I need a cam to find out who is stealing from me.
You don’t have a password on your WiFi? You are running an open unsecured network with all your devices and IP cams attached? ![]()
Test it by creating a guest network in the router with a unique SSID and PW and see if the cam will install and run.
It makes me nervous to hear you do not have a password on your WiFi. The goal should be to do everything you can to keep bad people off your network that might do bad things that could get traced back to you.
I should link a copy of this feedback in here since it is relevant to the Beta firmware…
TLDR; = The SD card playback is still skipping the first minute of every hour (except Midnight) on this V3 Firmware unless you start the playback within the first minute.
I tried this on multiple cams running this firmware.
@SlabSlayer I remember you tested this pretty thoroughly previously. If you have this beta firmware, do you want to confirm it’s still acting the same for you too?
Confirmed. Still skipping the first minute of each hour except the first hour of the day.
Also confirmed that when dropping the timeline within 10s of the hour, it will automatically jump across and skip that first minute. However, I believe it is because the timeline time indicator that hovers over the video isn’t synced with the timestamp. Dropping the timeline anywhere specific results in the timestamp starting to play 5 to 15 seconds ahead of where it was dropped. It is impossible to start the playback on a specific second.
Thank you, that would explain the new problem I was trying to describe.
My router has good security. Everything worked before the update, now nothing. It seems as my cam is shot, it will not connect.
There are other Wyze Cams that will not operate on an open network. The possibility of that being introduced in a new firmware update is low IMO.
It is also possible that the Flash wasn’t successful. I have had many V3 that don’t feel like taking the flash update. Getting the dual light and letting it restart completely is key. But, the reason for the flash trouble is usually the SD Card. I have some SD cards that just won’t work…cheap. Use only a high quality 32GB FAT32 freshly full formatted (not wiped) SD Card to drop the .bin file. If 4.36.9.139 doesn’t work, I would try 4.36.9.131 or 4.36.10.3406 which are also available for download.
You may have security settings within the router to protect from remote attacks. That guards the back door. But you have the front door wide open for anyone within range to walk in and poke around undetected. Should any one of them be operating with less than angelic intentions, that is on your IP, not theirs. If this is a free WiFi for a business, that’s fine to have an open network so long as it has a very robust site, streaming, and protocol restriction package. But that should only be on the Guest Network, NOT on your personal or business network with all your devices.
