I have two WyzeCam v3 (each one bought at different time) connected to Wyze app and to Alexa. They both work fine in Wyze app, but only one has live view in Alexa. The settings of both of them are identical, and I tried anything I could think of to get it working, but no luck. Doesn’t matter what I do, one always has a live view, the other doesn’t.
I contacted Wyze support, but so far, haven’t gotten any solution from them.
Did anyone have a same issue, and if you solved the problem, what was your solution?
