Wyze Cam V3 No audio from SETUP button
I have followed all the steps to setup a Wyze Cam V3 and when I get to the Press the Setup button, there is no audio saying Ready To Connect. Do you have any advice? Below are my details:
  1. Plugged V3 camera into a USB 2.0 port.
  2. Red light is flashing
  3. I have the Wyze App open and have clicked ADD. I am looking at the screen that says “Press SETUP under the camera”
  4. I press the Setup button but I get NO audio message.
When I press the setup button, I do not feel any click or feeling of a button, it is just a rubber pad?
You may need to press a little harder. Use your fingernail or a “soft” pointed device. The basic answer is you aren’t getting the setup button depressed enough to activate.
Is this plugged into the wall plug power adapter that comes with the cam or a USB 2.0 on a computer or other brand adapter?
I solved the problem of the SETUP button not working. I used tweezers to remove the SETUP cover and I saw a small button inside. I pushed the button with the tweezers and it worked. I am not sure why pushing the button in a normal way didn’t work but I got it to work.
Give yourself the Green Solution Checkmark :white_check_mark: for the ingenuity!
Be sure to put the rubber plug back over it so that it remains weatherproof!
My original issue was NO SIREN, and after deleting device per wyze help, no audio from pressing setup button. I did remove seal and press button with paper clip, I also went to next step.,… no luck :pleading_face:
Did you try and perform a Factory reset on the cam immediately prior to attempting a setup?
If you still get no “Ready to Connect” after that, I would go to the Customer Support Warranty Returns Portal and Request a Warranty Replacement RMA.
Received a gift card for the purchase price alread. :wink:
