Wyze cam V3 and V4 connectivity issue and blinking blue light
Hello all,
I have 3 wyze cam V3s and 2 Wyze Cam V4s. I am having connectivity issue with these cams. If I am not on the same wifi it wont connect to camera until I restart the device from app. And I also realized that cameras are constantly blinking blue. Power cycle or restart works briefly, then it goes to blinking blue again. Anyone encountering same problems? Any solution is appreciated.
I am having the same issue with the V4 camera. The V3 that I had before was working flawlessly. The V4 will go offline after a short period of time and I have to power cycle it to go back online. I have factory reset it twice and still the same issue. Not sure what’s going on. Hopefully a firmware update will fix it.
I would return them and try again or check out your network.
