Currently on one of my cameras I have a brand new 32gb Wyze sd card and when installed the camera states it only has 1.86gb available. Is it a faulty camera or faulty card?
Did you format the sdcard?
Sure did. Used the Camara and also used Comp and tried multiple times. No love.
Try the card in another camera, and if you see the same thing there, then that sounds like a replacement case for the card.
Keep in mind that this forum is primarily a user to user community. If you don’t get a helpful reply here, please file a Support Request. Depending on the nature of the problem, rather than use the previous website link, it is helpful to submit an App Log and/or a Firmware Log.
Thank you for your input I will try another camera and worst case will contact support directly if needed.
