Wyze Cam V2 -- cannot turn off sound detection
I have two Wyze Cam v2 cameras and one Cam v1. All are on the same Wyze account. The Sound Events toggle under Device Notifications is pale and unresponsive on both v2 cameras, but works normally on the v1. Both v2 cameras have current firmware, Cam Plus Lite, and notifications enabled. Record Sound Events is disabled. Why is the Sound Events notification toggle locked on both v2 cameras? I don’t want to receive notifications for sound!
I haven’t seen that interface, but maybe turn sound events on, which will unblock the notification setting, turn it off, then turn the events off again? On the newer cams if you disable sound event recording, there are no notifications possible for sounds.
That greyed out toggle usually means the app treats sound notifications as tied to the detection setting underneath it. On the v2 with Cam Plus, the Sound Events notification only becomes adjustable depending on the state of Sound Detection in the camera’s Detection Settings. Try opening Settings, then Detection Settings, and switch Sound Detection on, then go back and turn the Sound Events notification off. After that you can turn Sound Detection off again and see if it keeps the notification off. If it stays locked, force close the app, update it, and check again. If the toggle is still stuck, contact Wyze support with both camera names, since the v1 working normally points to an app side issue.
That did it! Turn sound recording on, Turn notification off for sound. Turn sound recording off. Goodness, what a convoluted way of setting things.
Same as other reply: That did it! Turn sound recording on, Turn notification off for sound. Turn sound recording off. Goodness, what a convoluted way of setting things.
