Wyze Cam v2 and Pan firmware 4.X.6.199 Released - 10/21/20
Try turn off 5ghz. radio in your router.
channel to 1
20mhz
As @cf7 says and make sure your Mobile Data is turned off. That has caused problems.
Also the WiFi password. Sometimes a smart phone will alter w/spell check -or-
if copy/paste will add a space at the end of the pwd.
No worries. There is almost always a screen somewhere near the DHCP settings that shows a list of connected devices by MAC address - which should be on the sticker on the bottom of the camera.
Are you hearing the Wyze cam say both ā€œReady to connectā€ and ā€œQR code scannedā€ as you go through setup on the phone? That might help pin down where exactly in the process things are failing…
I’m using the 199
I updated one of the Pan Cam to this version of the firmware. It disables the pan function when I tried to turn on the detection zone and vice versa when I turn the pan function on it disable the detection zone. Also, it gave an alert every 5 minutes when it is panning around when there is no motion detected,
thx many advices.
Wyzecom say ā€œReady to connectā€ and ā€œQR code scannedā€
then "ā€œCannot find the specified network nameā€
All your advices has done.
Wyze Team say ā€œthis is a very unique caseā€
It means give up?
Interesting…
Either your wifi chip in V2 is dead or loose antenna.
Did You reflash firmware?
what version now?
what brand model of your wifi router?
New Wyze App really have a connect to V2 issue and does not help.
From the replies, I’m glad I passed on this update. Trust must be earned.
Any updates on this? I’m also affected by the timezone bug on the outdoor cam. Thanks for fixing the other cams so quickly too, great to see how responsive the team are.
Now firmware 199
I try webcam firmware , its work well.
My router is NEC BL900HW.
My Wyzecam and router work well before update191.
I have lots of Wyze problem too with my V2.
May be you can an flash to 156 firmware?
not sure if it is still available.
if not, contact Wyze to get a copy. but their customer services does not have hi
I kind of fixed my issues.
turns out the sd card is corrupted (suspect from firmware upgrade)
if you habe sd card, try start without sd card, if it connects. format sd card and pit it back. I used exfat.
Hi @cf7 Loading the firmware might expose bad cells but wouldn’t cause the corruption. Here are a few suggestions:
To test if its a corrupt uSD card.
  • Remove the uSD from the camera and test it in your workstation.
  • Check the disk (uSD) with the command line C:\Windows\system32>ChkDsk X: /r Where X is the uSD card
  • Format the uSD card FAT32 and un-check the default ā€œQuickā€ option so it can mask out bad cells.
    Note: The Format from the App is a Quick Fromat
Quick format just marks the partition as ā€œformattedā€ and destroys the journal that keeps tracks of the files and their locations on hard drive.
Full format will clear files completely from the partition, rebuild the file system, volume label, and cluster size, and scans partition for logical bad sectors; that’s why full format is slower than quick format. Wyze devices must always use the FAT32 format.
I updated to this firmware. Work good for two days now my Wyze Pan cam s totally dead. No lights nothing. Any suggestions?
Hi @njohnsonn1 Not much to go on though doubt trouble has much to do with firmware udate. There have been problems on the Pan Cam with power and USB connectors.
Check there first:
  • Different outlet and power supply
  • Substitute new USB cable
  • Check USB sockets, loose, bad connection?
That will be very strange. Only have it less than 4 months now
So i did the suggested steps and it looks like the charging brick is not working. I switch it with another cam i have to confirm. I will have to get another are they sold separate? Or what the specs if i have to use a replacement.
Hi @njohnsonn1 The spec is 5 Volt DC at 1 Ampere (1000 ma). Most of the cell phone chargers are 2 amps and will work just fine. You might give Wyze Support a call and see if they’ll ship you one. Otherwise BestBuy, CVS or Amazon have them.
(206) 339.9646 Live support is available: Monday - Friday 5 am - 6 pm PT
Is Wyze going to look into this issue or just leave it open ended? I have one cam that is still on version 4.1.0.5.111 and does not have these two issue the latest .199 version?
The version 4.10.6.199 fixed an issue with time zones +13 & +14 from GMT.
Try a Manual Flash back to 4.10.6.193 (October 5, 2020) and see if that helps.
You may need to open a Wyze Service Ticket if the Pan Cam is having trouble with both the newer versions.
Live support is available: +1-206-339-9646 M-F 5 am - 6 pm PT
