I can see my events but it says cameras have bin deleted
@boehld1
You can find more about the issue in the link below
After update (disappointed with myself for jumping on this update so fast) our Pans are stuttering. They will pause video and then skip to the current time and then pause again after one, yes just one, second. Weāve tried rebooting everything and three different devices for viewing. Still pausing and skipping. Anyone else seeing this fun undocumented feature?
@Nettmon Welcome to the Wyze community!
Donāt beat yourself up over the update, because it is happening to those that didnāt update as well. Wyze currently is having server issues so it isnāt on your end. Itās best to wait it out until they get everything back up and running again.
Hi @Nettmon and yes, welcome. I thought Microsoft had the copyright on āUndocumented Featureā.
StopICU is right, there is a lot of coffee brewing at Wyze to get things right. We users are geting back service but its intermittent.
Hi @UserCustomerGwen & @XuLi
Is there a plan to update the Outdoor Cam to sync w/GMT+13 and +14 time zones?
@Steve0_NZ wants to know.
my wyzecam V2 completely broke due to the update firmware191.
193.199 cannot restore it.
all support couldnāt solve the problem.
very disappointed
what is broken?
Hi @Toshi, Once in a while the update doesnāt take for a number of reasons.
Did the Wyze Support walk you through the Manual Update Process?
Its fairly reliable at resurrecting a dead cam.
Iāll ask the team!
Wyze Team, I just installed my new Cam2 and got it setup and connected. Then I received the āupgradeā notice. So I complied and the upgrade failed leaving my camera in a solid yellow light state. This should not be so painful. Any useful comments before I return this?
have U tried reset?
if not recover
download older firmware and install it manually.
Nothing worked so I did download the software update as the release notes suggested and I got it to work. The setup button is a bit unpredictable, it took me 3 tries to press the button and plug in to have the device pick up the software from the card. 3rd time seemed to be the charm.
Glad U got it installed.
From your description, I suggest to check your internet bandwidth, number of actively connected devices.
You might have traffic jam in your place.
My wyzecom cannot connect network.work only webcam firmware.
I have done all I can do.
manually change firmware 156,193,199
factory reset
reboot router
wyzecam close to router
replace router
change phone devices
send log to support team
The developer double checked the log file you submitted and nothing to be wrong in there but it just canāt access your router.
Is there anything more I can do ?
Looks like youāve covered most of the bases. Couple things to check:
Make sure your camera is on the 2.4 Ghz WiFi and not the 5 Ghz.
Can you check the routerās DHCP log and see if it has issued an IP address and the camera has accepted it.
Thx
Ofcourse 2.4ghz
Sadly, my router cannnot isuue log.
Hi @Toshi If you can, use another secure WiFi at a friendās house or restaurant.
If the camera works there youāll have isolated the problem.
