I have Wyze cam unlimited with 12 cameras and the bird feeder with the wyze battery pro camera. If you turn down the sensitivity does it make is “more sensitive” (likely to pick up a bird) or less sensitive? It was sending notifications for “pets” when I first set it up, now it stopped (when birds are there) but will send a notice if I walk up to it (person) any ideas why no “pet” detection" Also, I saw birds in it on my ipad, hit record for 30 seconds. It recorded (or said it did) but the video is nowhere to be founds. With wyze cam unlimited How do you go online and search for recordings? Is it only through "events’ in the ipad/iphone? Doesn’t it save the video for future access?
Higher sensitivity makes it more sensitive. 100 is the most sensitive. Lower will require a larger object or an object closer to the cam in order to detect an event.
If you hit “record” manually that records to your device, not the cloud. So it would be in the gallery in the wyze app on that specific device (also in the device’s gallery somewhere also).
As @dave27 the recordings will be in the Wyze app gallery, more specifically in the Album section. It will also be available in the Photos app on you iPhone/iPad.
