If I powered the camera (motion detection) from a vehicle and the vehicle wasn’t started how long do you think it would power the camera for before it drained the vehicle battery. I know vechile batteries vary in capacity but just an educated guess. Would it last a week?
thanks.
Well my dashcam will last about 2 days before i cannot start the car. Only using motion detection you should be good unless you leave it there for days. Also it would be set off all the time when a car drives by or a person walks by.
So, are you powering the Wyzecam with 12 volts instead of the typical 5 volts from the charger? Any power issues?
