Wyze Cam Pan V3 Stop recognizing SD card
Wyze Cam Pan V3 stop recognizing SD card. Card seems to be ok as i can see the photos, video from the SD card using WindowsPC. I have formatted to Fat32 using windows PC and tried again, still not able to recognize.
Firmware : 4.50.15.4800
Welcome to the Forum, @Blazer! :wave:
What did Support say when you contacted them?
When you search the Forum for relevant topics (:backhand_index_pointing_left: this link is a pre-built search), do you see any that seem to describe your experience? If so, then you can respond here to let the Moderator team if you’d like your post moved to one of those. There have been so many topics regarding microSD card problems with Cam Pan v3 that we’d like to see your concerns addressed and get the visibility you want rather than being yet another new topic discussing this same issue.
Also, what additional troubleshooting steps have you taken? I’m thinking here of things like trying the same card in another Cam (if available), trying a different card in this Cam Pan v3, factory resetting the Cam, etc.
Including the Cam’s firmware version is good, so thanks for that! :+1: Sharing your app version might be helpful, too.
