Pan Cam V3 - MicroSD card not available
Android - up to date
Wyze app - v3.3.0.609
Camera Firmware - 4.50.5.1318
Other postings are about other cams or are more than 1 year old on similar topics and appear outdated.
1 of 4 Pan Cam V3 cameras began responding my tapping SD Card from the live view page for that camera with MicroSD card not available. It is not available in the manage SD card option either. I’ve triggered a restart from the app, and pulled power cord from the block plugged into the wall in an attempt to get it to reset and make the card available. I’m going to eject and reinsert, followed by replacing the microSD later today to see what that does.
Is anyone else having this issue?
If you go down the list of post here you will see the same issue has been posted numerous times.
One of many:
There is high probability by doing that to corrupt the card. I get it that you can’t use the eject feature in the app. Try and reformat the card using your computer and see if that fixes the issue.
