I find that no matter if mounted right side up or upside down, tilting the camera too far vertically, especially after dark, causes the view to be washed out by the infrared lights reflecting off of the surface of the second cube. This might be rectified by being able to adjust the connecting arm but that appears to be stationary and secure.
Possibly a flat black decal/sticker that would cover the cube surface could work or better yet, a flat black skin for the adjoining cube would suffice.
In any event, I find this to be a real issue. I use the camera for wildlife in the yard and when an animal gets too close to the mounting pole, the view is lost as the camera tilts down. Likewise, if mounted upside down, the image is lost of a critter climbing up a tree.
In my opinion, this needs to be addressed. Any suggestions would be appreciated.
I have not tried this but just ran across it. Looks like they have a matte black amongst other colors.
I suppose before you spend money on a wrap, you could try taping a piece of dark construction paper to the camera to see if it alleviates the IR washout.
Thanks for the info. Construction paper will not work outside. Heck, the included sticker is long gone and we haven’t had any bad weather since I installed it. Stickers not made for outside.
I may just try a couple strips of electrical tape though its not matte finish just to test. The entire top of the brain cube does not need to be covered, just an inch or so of it from the outer edge which is all the camera can see.
If Wyze offered a black model, that would eliminate the issue entirely.
I used a rather heavy, flat black gaffer tape and covered the surface of the cube closest to the camera.
Unfortunately, no change. I can only assume the camera is in too close proximity to the companion cube. The infrared lights generate an intense reflection, no matter what the surface is covered or dulled with, when the camera lens is tilted toward it.
