I’ve tried different settings and not getting the results I want. What do I set to get the most sensitive motion
trigger
The WCO detects motion best when it is across the field of view. Straight at or Away from the cam is not good. If I were you I would turn the face of camera a little to the left keeping your stairs in view. Try a few degrees at a time toward the yellow line on my altered photo attached. Also read this information. The bottom area in the light green is the PIR ZONE so I would also tilt the camera up just a small amount so it is closer to the end of the drive.
