Wyze Cam Floodlight won't manually update firmware
Thanks! I also have another v3 and there it works perfect. It might be some cameras with that hardware problem
No, I was never able to get the camera to manually update the firmware off an SD card or even do a factory reset.
If you mean remotely, the original problem is that a remote firmware update failed and the camera will no longer connect to any network.
I was able to resuscitate a couple of cameras bricked by bad firmware updates by flashing.
You’ll have to describe the process for me then, how it is different from what I have already tried many times.
Flashing is different from updating the firmware via the app. Wyze has instructions on how to flash firmware. The link is here somewhere.
