Wyze Cam Floodlight no audio when playing back from sd card
If you try to View Playback continuously saved to the SD card, the audio is silent. All you hear is a strange squeel once in a while.
The audio does play OK when you are watching the Event clips or live feed. Another funny thing: if I download an Event clip and edit it with Google photos editor, it will not play any sound when you play it back! Is this a software issue, like maybe a bad audio codec?
There is a setting near the bottom of the Advanced Settings page to enable or disable “Record Sound”. Sounds like you have that disabled.
It is enabled.
Uploading: Screenshot_20230217-134425.png…
