Hi folks, looking to replace a couple old motion detecting floods with Wyze Cam Floods but I cant seem to find the answer if these will work on my existing junction boxes. All the images I see are flush mounts. Can someone let me know if I can use my existing mounts?
It will most likely work with a non flush mounted junction box, but I’m not sure if it will be super water tight. You may need to have an additional seat in there. The floodlight is made for flush mounted ones.
The Wyze Cam Floodlight will attach to your junction box. You might need to apply sealant to the outside of the junction box to prevent rain water seeping into the junction.
