If you dim WyzeBulb to lets say 50%, and if you then turn switch off and then on, WyzeBulb will go to full brightness. Correct?
Ok I just did it myself, I turned on a bulb and set it to 10%, then I turned off the bulb at the switch. I waited a minute then turned the switch back on and it came on at the 10% that it was at when I turned it off.
Yes, the bulb will remember your brightness and color settings after loss of power.
Nice, that is totally different behavior than Philips Hue, as they would go back to full brightness.
I know this isn’t the Philips Hue support forum. However, you can change this in the Hue App under Settings → Power-On Behavior. Set each bulb to “power loss recovery” which will set it to the previous used color and brightness.
