Wyze Bulb Color - Broken color selection
I’m frequently trying to change the color of the bulbs to pure red (#ff0000). Though, the only way I’ve been able to do that consistently is through Google Assistant and asking it to set the lights to “Dark Red”.
With the color selector in app, the wheel won’t allow me to select pure red, green or blue and always includes some of another color. See below, regardless of where I select in the red zone, I just get some mix of red that makes a pinkish color (#fe0100)
That includes when I’m trying to set color for an automation…
In the past, the color selector worked for being able to select pure colors, and I think at one point you could explicitly type in a hex value, but that’s not an option anymore.
Just hoping to update the color selector to allow pure colors again!
I don’t recall ever seeing this for Wyze Bulb Color (or Light Strip or Light Strip Pro), but it’s been requested in the Wishlist:
It’s been mentioned as a request for Automations Actions, as well:
As with any Wishlist topic, you can visit those to click or tap the Vote button above the initial post and share your ideas and use cases in the comments to show your support for the product and feature request/suggestions that are important to you.
