Please make the case a little bigger to support memory foam tips. I can not use the rubber ones with this style ear buds. It is painful after a few minutes of use. The memory foam tips allow me to wear as long as I need. The problem is I can’t close the case with memory foam tips installed on the ear buds. So I have to remove the tips befire putting buds in case.
[Mod Edit] Title changed for clarity.
