Wyze bud pro case case?
Hello! I’d like a case for my wyze bud pro case. Any suggestions of where I can find one or which one will fit?
Welcome to the forum @Berfdaysut!
I have not used any of these, but I imagine something like the below would work based on the size of the WBP charging case.
https://www.amazon.com/Carrying-EarCater-Bluetooth-Earphone-Cables-Red/dp/B07FQCRG17/ref=sr_1_3?dchild=1&keywords=Oval+shaped+headphone+case&qid=1631890290&sr=8-3
https://www.amazon.com/Small-Hard-Earphone-Earbud-Case/dp/B0854Q5YQT/ref=sr_1_14?dchild=1&keywords=Oval+shaped+headphone+case&qid=1631890366&sr=8-14
https://www.amazon.com/Geekria-Silicone-SoundBuds-Protection-Earphone/dp/B0798L3K3S/ref=sr_1_7_sspa?dchild=1&keywords=oval+shaped+headphones+silicon+case&qid=1631890401&sr=8-7-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzSE5KUTBFU1dNVExJJmVuY3J5cHRlZElkPUEwOTU0MTEzMkVJUVBIN0dDSkRMVCZlbmNyeXB0ZWRBZElkPUEwMzQ3MDM2MjgxWU5CSkQ2NVg3NyZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
I had an extra silicone airpod pro case from amazon - quite inexpensive - and for the most part it fits well.
Hello everyone, this may not be practical for everybody but this is more a message to wyze. My wife would borrow my wyze bud’s all of the time, and I offered to buy her a pair numerous times but she always said no because she said that she would lose them because the case didn’t have a clip, so I took a old fishing rod tip and a piece of broken dryer belt filed it down and used liquid weld to hold it in place, she liked it so much that she kept mine and I ordered another pair. I love wyze products and would love to help develop something like this for the future, sometimes it’s the little things that make a big difference.
Thanks
I have a few different silicone cases for my AirPods Pro’s and all of them fit the Wyze Buds Pro. Some fit tighter than others but all the ones I have work (4 different brands). I would recommend ones that the case folds down to flip open to prevent the lid from opening unintentionally. Many are also water resistant if they have this feature too.
Have you tried it cut a hole for the charging port? If so, how does it look?
No need to cut into silicone. Has a little cutout flap already at base and I never need to take out of case!
I think I should develop a case for these, but case because everybody either a drop stairs and scratches out of the case, or they just need to wait to hold onto their headphones without having to put them in your pocket the case, and having to carry the case in their pocket all the time because they don’t have the case with a little hook on where she could hook them onto the pants when they’re using them so they’re not having to rely on just keeping them in their pants pocket
