Wyze Band reset?
Hi all. What troubleshooting steps do you recommend for a non responsive Wyze Band? The device is 100% charged but not responsive, the home button light is on but the face doesn’t respond to input. Any way to reset it or reboot?
Thanks
Hi @Fleiva,
Go to the Wyze app and see if the Band will reboot from there. If this doesn’t help post back. Thanks!
  1. Open the Wyze app and tap Wyze Band .
  2. Scroll down to the Settings screen. Tap Reboot Device.
Wyze Customer Support
For further technical support, you should contact Customer Support (206) 339-9646 Monday - Friday 5 am - 6 pm PT and Saturday 8 am - 4 pm PT or make a Support Request online.
Thanks for the suggestion. The device battery fully drained and it was responsive again once I charged it. I will try you’re suggestion if it happens again.
