Good day,
Recently, I have been having issues with arming and disarming my Wyze Home Security System with the Wyze App v. 2.50.2. Is there a fix and/or resolution for this issue?
Ray…
Good day,
Ray…
Are you able to update to the latest version of the app and see if that resolves it?
No luck…
What issue are you having? Are there any errors? Screenshots?
You could try this: Mode switch failed. Please try again - #10 by tedd
That person didn’t put in any further replies to it likely was solved by that as they stated at that time.
