When I watch video from a camera in the iPad app (current version of iPad OS and of the Wyze app) in landscape mode, the name of the camera in the upper right corner is partially “under” the info Apple displays at the top (time & date). That’s the same part of the screen that needs to be touched to exit the camera view and go back to the device list. The app does not respond. The only reliable solution is to put the iPad into portrait orientation. Appreciate some adjustment so there’s no longer a need to change iPad orientation.
Are you on App version 3.11.6.1 and IpadOS 26.4?
iPadOS 26.4, Wyze 3.11.5(4)
Maybe an update to Wyze?
I updated the Wyze app - same problem,
I have Cam Plus Lite and my v3 cameras are on firmware 4.36.16.6114, but not sure if that makes a difference.
