Wyze app notifications bell turned off
Greetings all, this is my first question, Hope you can help me. Some times i don’t get notifications when movement is detected. When I open the app on my Samsung Galaxy flip 6 mobile, the bell in the right hand corner shows the line through it, i.e. no notifications or turned off, but as soon as the app has opened it appears to turn on. I assume you don’t have to have your app open the entire time you have your phone on it, is that correct. If not, then why does the opening of app appear to instantly change the bell from off to on. Thanks all Leighroy
Could just be the local app is syncing with your account settings in the cloud. What actual app version are you using?
app version is 3.2.7 (595)
Wyze has mastered this skill. Settings get flipped. My BPC camera turns on after repeatedly turning it off.
