Wyze app mutes system volume by 90% when used on MacOs
As mentioned using the app on MacOS breaks the sound on the system. You can compensate if you’re using an external sound source (I have to max out my home theater’s volume) but while the process is running it completely takes over the sound of MacOS.
Are there alternative ways to use Webcams via a webpage or another App on MacOS?
Or is there another brand of cameras I should look into that will allow me to watch multiple live streams on a side monitor while I’m working?
I just want to be able to view camera streams on my mac and i’m tired of live cams that only work through apps for tablets and phones.
I find force quitting the Wyze app clears it
This is annoying as hell because I use my Wyze cam exclusively when I want to play loud music (make sure my flatmate’s car is gone). What a dumb behavior.
