Wyze cams on MacAir.... can this be done?
Is there a way to view my indoor and outdoor cams on my MacAir?
The only method i can think of is to use the WEBView if you have Cam Plus. Note: it is still in Beta and being worked on to provide the best viewing experience.
Off hand, I am not sure if there is another method.
If it has an M1 chip you can also emulate iOS, and load the iOS Wyze app:
