I use the Android app (2.45.0.b333) on multiple devices and have had to re-login about every 3 days (using username+pass each time).
BTW. I have had no issues running in Android Nougat 32-bit on BlueStacks on the “old” app for about 2 years, but have had multiple login issues with the beta (2.45.0.b333):
BlueStacks, Nougat 32-bit (Android 7): the login hangs after entering username and password
BlueStacks, Android 11 64-bit: the login hangs after entering username and password
BlueStacks, Pie 64-bit (Android 9): works, but have to re-login after ~3 days
Samsung Galaxy Tab7+, Android 13: works, but have to re-login after ~3 days
Is there, maybe, a minimum version of Chrome required?
For those experiencing the repeated need to log in, the next time you are forced to log in, right after logging in can you submit a log and let me have the log number?
I am experiencing the login request on both IOS and Android version 2.44. Everything is fine once I enter my password. Do you want Log numbers for 2.44 or only 2.45? Asking so I don’t muddy the water for you.
don’t know if this is toooo late but I just started using Brave and they do have a blocker - if you flip the switch to allow a website an immediate window shows up to write why you unblocked it and I always put in a reason. I don’t know how much it really helps but I do use a cloud based software for insurance agencies with probably 10k people logging into it so they are a safe URL and I don’t think I have the blocks happening any more…
Trying everything and see what’s kicking everyone out. Cache clears, restarts, different types of force clothes on the app, I just cannot figure it out. It’s got to be something on the back end. And I didn’t pay attention enough to figure out the time frames in between the two or three times I’ve had to log back in to see if it’s something automated. Anybody have any idea on that one?
I don’t do anything special. within a 24 hour period of time, my Pixel 7 Pro will require me to logon, so hopefully this install will alleviate that. I will see tomorrow morning.
My Z Flip 5 did not experience the logoff issue except for once. My Razr Plus had issues but not as frequent as the Pixel 7 Pro.
Can’t login to app/webpage using brave with fix outlined above or chrome. Error from both says invalid client or context, please access page through wyze app or official website. I can login to the official website obviously. Would like out of the beta program so I can actual use a product I’ve paid for but as I understand I need to opt out through the app, which doesn’t work.
Android, Galaxy S21
I just got the login prompt again. I now have a note to track that in case there’s some sort of pattern there. It’s something I hadn’t thought of before.
If there’s any finding there I’ll let you know but considering how quickly they’re looking into this I doubt I’ll find a pattern before we have some sort of hot fix for it
