Hello friends,
Can you believe that it’s March 2022 already? I don’t know about you, but I believe there are good times ahead of us in 2022! Here in the Wyze AI team, we are working hard to create great things for you! Check out our latest updates!
What’s Going on with AI Detection?
In the past few months, we’ve been primarily working on improving the accuracy of specific object detections. We’ve come across some issues that caused us to spend more time than expected to re-train the model. Umm… Yeah, sometimes it happens. It’s sort of like teaching your kid again that minions are not bananas. (They aren’t, right?)
But we finally got there! After a couple of model iterations, we’re seeing improvements in several subcategories including Pet Detection and Package Detection especially for the doorbells.
In addition to general Cam Plus AI updates, we are also investigating two types of resources to further improve performance: 1) a better new AI model and 2) typical scenarios where false detection rates are higher (e.g. night vision, labeling pets as people, etc.). Stay tuned!
Try Cam Plus Pro for Free!
We combined AI detection and professional monitoring so you can arm your home with just one Wyze Cam! Sign up here and check it out for a 2-week free trial in the Wyze app once you’re enrolled! Cam Plus Pro sends you an alert when your camera detects a person and gives you enough context with video clips to decide to dismiss or move forward with the alarm using Noonlight. We also added Friendly Faces (facial recognition) to Cam Plus Pro. Share your feedback with us to help make Friendly Faces better! You can learn more about Cam Plus Pro here.
Try Sound Detection (Beta) on Wyze Cam v2 and Pan!
Thanks to all the testers who helped us build our latest and greatest AI sound detection! Currently, Sound Detection is still in the beta testing phase for all Cam Plus users. You can enable this beta feature for your Wyze Cam v2 or Pan by going to Camera Settings > Event Recording > Cam Plus AI Detection. You will need sound detection enabled to use this feature! If you don’t see the option, please update to the latest firmware and make sure your Wyze Cam has a Cam Plus license attached.
We hope you all have a good time trying out our new AI capabilities! And please don’t forget to share your feedback with us by tapping Yes in Event videos to help teach our AI algorithm what it should have detected instead if it misses the mark.
Best,
Kim from the Wyze AI team
